Wow no response for 2 days?! Everyone is on vacation.
your CYA still looks high. use the chart to see how much more chlorine ppm you need with high cya.
FC/CYA Levels
50-60 CYA may be a better level to manage FC levels more easily. Unfortunately that means drain and more fresh water to reduce CYA. Then you will need to do the SLAM process FULLY to kill all the algae. Read other posts about scrubbing the heck out of everything touching the water too. Lights. Ladders etc. to get rid of hiding algae.
