- Jun 27, 2008
- 11
Hi folks, I would like the forums feedback on my thoughts. I like to add back a SWG to my pool system. I have limited options (space) to add in a SWG cell after the heater and return lines. See pad layout below.
As you can see by below diagram it believe the Jandy TruClear cell will fit nicely and will only take a few mins to install.
I know the cell output capacity meets the specs for my pool size however I know it should be over sized to 1.5 to 2 times
Jandy Pro Series TruClear manufacturers specs
For a short Canadian pool season ~180 days and my pool size
Will a Jandy TruClear be sufficient or undersized? I assume I will need to run the unit at 80 to 100% all of the time. (read below)
If not the anyone recommend a different unit that will fit in my pad and piping?
Thanks
Specs
Inground, vinyl liner pool
20,340gal or 77,000L
Test kit is Taylor K1004 with added FAS DPD kit
Sunlight will hit 92% of the pool for about 85% of the day.
Live in Canada - pool run time time is ~180 days or ~4320 hrs per season
In 2021
New liner replaced in Aug and fresh water with zero CYA
Pool pad was rebuilt with new heater, all new 2" piping, new 2" head/sand filter and New Jandy Vs FroPro, new water feature pump
Pad setup in unique since it has 2 pumps. VS pump for 24hr circulation/filter the other pump is for the water blade feature that can be turned on demand with remote options.
Original Chlorination before rebuild
Was using a DelOzone Tro Pure 20,000g unit SWG Cell and 2 Ozone cells. Unit worked great for 10 years (1ppm FC all year was all I needed). Unit was old and had several issues, It was discontinued so I retired it. I also have a hayward 3" dispenser which I use to open the pool for the first 2-3 weeks and end of season when the water temps are below 60F when the SWG is not recommend to use at that temp. I also use the CYA in the pucks to get it back to 40PPM after winter drain. Never an issue. Water sparkled
COVID and 3" puck dispenser
Last year during COVID and closed stoes etc... I thought I try to only only the 3" puck dispenser (first year) and use liquid on days when pool needed an extra boost or to shock. Well that was a disaster. The neighbor cut all the trees down that shaded my pool all year. This was great for keeping the pool warm but learned a new problem. Late July CYA was way to high and by Aug it was over 80+. I dont have a test for CYA, put used the pool store to do water sample. One test was 90 the other was way off and I did not trust the spin disk tester. I assumed CYA was 90 to 110 but never sure. Another store used Taylor drops said CYA was 80 late July.... I ended up having algae reappearing ever 5 to 10 days after shocking many times and discovered I would lose the pool clarity very quickly (algae bloom forming over night). At that time i was keeping FC @ 3-5. CC was always zero until I lost control of the bloom after i was away for the weekend. I then kept FC ~15ppm for the rest of Aug and SLAMed to 20-27. Too scared to SLAM to over 30ppm since it was a brand new $5000 liner. Stopped using pucks first week of Aug after I cam back from holidays. I was burning up 1-3L (pool store CL @12% maybe) per day and seemed like a 20L carboy every week.
Cut out Injector T and union and put in a Truclear
- Maximum Output of Hypochlorous Acid is 420 g per Day @ 3000 ppm
- The maximum volume of water with one TruClear is 132,000 liters (35,000 gallons)
Thanks
Specs
In 2021
