I've done great at keeping my pool balanced up until last year I kind of gave up on it. When I closed the pool last year I rushed it and I opened it to a swamp. Got the water clear, but I have what I believe to be algae stains along the edges and my pH is out of control. I haven't tested this year but my TA is usually really high.
So my questions. What is the best way to lower TA and clean stains that don't scrub away with a brush? Went to the pool store and he recommended using granular shock and sprinkle on the stain, let it sit for a minute then scrub. He also mentioned mixing a gallon of water with a half gallon of acid and pouring it in opposite sides of the pool away from the filter. Letting it sit for a while then run the filter. Does that sound right? I have the TF test kit and generally know what I'm doing, just looking for the simplest solution so I don't get frustrated and drive my truck through the pool. TIA.
