Quick history of our operation:
I am NSPF certified and I run the bodies of water at a hotel/health club
1 33k gallon pool
1 75k gallon pool
3 spas 1300, 1300, and 1800 gallons.
For the past 10 years we have been using cal hypo as our sanitizer for all of our pools.
However, we do it differently than anyone else I've seen.
We have two tanks per pool house. One tank is a mix tank and one is a draw tank.
Into the mix tank we add 1oz cal hypo per 1 gallon of water. These are 100g tanks. Once everything is mixed and a few hours have passed for the sediment to settle to the bottom, we siphon the cal hypo mixture from the mix tank into our draw tank.
From the draw tank it gets fed into our bodies of water through chemical feeders and chemical sensors (we are using chemtrol ORP and pH).
Here are my questions:
1. The cal hypo clearly states to not pre-disolve, yet we do. Can I get an explanation of why you wouldn't want to dissolve before adding to your pool from a chemical standpoint? I have a feeling we are making the cal hypo not as effective but I do not have the chemistry background I'd need to understand the chemical process that could be happening by dissolving it first.
2. We go through a whole bunch of it. I have gone through all of our pool orders for 2018 and we went through 4000 lbs of cal hypo. At the dilution rate we use, that's 64000 gallons of liquid calhypo/chlorine. Does that not seem like an astronomical amount of chlorine for the amount of water we have? Dont even get me started on the CH.
3. Clearly if we were to switch off of cal hypo to liquid chlorine it would have to be much more potent because 64k gallons of chlorine would be a nightmare. Which is what leads me to believe we aren't getting the full potential from our cal hypo by pre mixing it
4. I want to switch to SWGs for all our bodies of water. The owner is the one who isnt quite for it. We live at the beach so we are already very much aware of the corrosive effects of salt. Our large spa and our largest pool is surrounded by an aluminum structure/building which has shown signs of corrosion over the years. He is convinced that a salt water pool would compound this issue greatly. I am not as convinced and think that the issues we see from using cal hypo are much greater. The other bodies of water are outside open air and aren't a concern as far as corrosion.
5. What would you do if you were in my shoes? Switch to swg? Switch to liquid? Other options?
Thanks everyone for your time.
-Brandon
1 33k gallon pool
1 75k gallon pool
-Brandon
