Mysterious stains suddenly showed up
Ugotabkdin
17
Sacramento, CA
new stains showed up suddenly after a week or two of rain during which I didn’t stay up on brushing, etc. It’s old plaster that has a lot of other widespread brown stains, but I was hoping to avoid any further staining…
The new stains are these tiny brown stains. Like flecks or brown. See pics; this is only about the dark brown, very small well defined stains—not the discoloration you see around them. Only the dark flecks are new.
. I have shocked pool, scrubbed the stains, applied muriatic acid directly to them, applied ascorbic acid directly to them. Nothing changed the stains one bit. I’m stumped.
See pics. Any ideas?
If ascorbic acid had no effect, you can rule out rust from a metallic object rolling around in the pool. Do you have any organic material falling into the pool from nearby trees? Look up tannin staining and see if it applies. Tannin oil is found in variety of trees. Maintaining an elevated level of FC should fade the stains over time.
Yeah there has been lots of debris falling in pool. Not really in the one area where the stains are, so that’s a bit weird. But I will maintain extra FC and see how it does. I guess that’s a good outcome if correct…
Update on this. I’ve maintained high FC for weeks. No effect on these stains. Ugh. Any other ideas?
same problem...it's caused by contamination...the pebble (most likely) and/or the abalone shells have some metal in them...pool needs to be resurfaced otherwise they will never go away!...make sure all contaminants are removed from pebble (i think they use magnets to filter out all stones that have metal in them)...
I don’t have pebble. Regular plaster.
I checked to make sure it wasn’t iron. It definitely isn’t. My working theory is now that it is caused by bits of wisteria seed husks. Somehow embedded in a way I can’t scrub out. Maybe a long shot. But I will know more once I get in pool.
Otherwise I just can’t figure it out. They are all concentrated on the side closest to where the husk bits would find their way into pool.
