Hi,
I'm trying to to figure out or pictured what is going on inside my skimmer and pipes during the freeze spells.
Situation...
2am single digit temperature and high wind
Power shut off and then came on right away at 2am (rolling blackouts started) that is how I found out about the skimmer Is blocked with ice.
Rolling blackouts
Near skimmer weir door got blocked with ice
No water getting into near skimmer (not sure how long this was happenening)
Removed ice. Water fill up skimmer
Power came on, pump tried running because I saw sheer descent trying to get water going and spa water movingq. It stopped quickly maybe less than 30 and never started again (everything was quiet).
Panic mode- shut off circuit breaker.
Saw pump still has full water in it.
Drained pump, filter, heater
Back to sleep...actually got on TFP and then start googling evrything and really never sleep.
Is the water coming into the skimmer goes straight to the pumped first?
What do you think is going inside that near skimmer?
Do you think my pipe had froze when the skimmer is?
Will it burst when temperature warms up?
Do you think the pump is ok?
Thank you
Sorry so long
Situation...
Rolling blackouts
Thank you
Sorry so long
