Hi There,
This may be long which I fined scares a lot of people away but I try to give as much history and detail as possible in my initial post so please bear with me.
So I have had my above ground pool for 8 years and 6 of those 8 years have been trouble free. Last year I noticed the cell on my salt water chlorinating system was not producing that white cloudy water after it passes through the fins and with in days my pool went green and I discovered I needed a new cell at $500 taxes in. I got everything back in order enjoyed the rest of our short Canadian summer and closed the pool on our Thanksgiving weekend which is the middle of October. When pool was put away the water was free of organic waste and the water was clear. As the ice started to melted this spring I could see the water was green even though there was still 2-3 inches of ice around the pool. I have never seen this before. Due to weather and commitments I was really late opening the pool and the water was super green. I went to my pool place with a water sample explained water was green they gave me a 48hrs pool opening kit and 4 20kg bags of salt. In the past this has worked with no issue and were off to the races. This year that has not been the case. So my pool went from green to milky and it took 2 treatments to go from milky to clear. Presently it clear but every time I bring a water sample to them, they keep saying I have no chlorine in the pool.
I have a new cell from last year that has maybe 6 weeks use from last summer and 3 weeks use from this summer. The power supply to the cell is 8 years old but has been kept in my house and has never been exposed to the elements, all lights are working as they should. The cell is producing that cloudy water after passing through the fins ( I have always assumed that's chlorine being made before being returned to the pool )
So here are my last 3 water samples. We are starting after I used the 48 pool opening kit with 4 bags of salt.
2 Weeks ago
Visual Inspection Foggy Water
Your Water Has A Corrosive Tendency!
Salt= 3700ppm
FC= 0.07ppm
TC= 0.07ppm
TA= 32ppm
CH= 86ppm
CYA= 10ppm
PH= 7.2
1 Week Ago
Salt= 3700ppm
FC= 0.08
TC=0.08
TA=105ppm
CH=78ppm
CYA= 8ppm
PH= 8.2
2 Days Ago
Visual Inspection Clear Water
No Corrosive Water Alert
Salt= 3700ppm
FC= 0.15ppm
TC= 0.15ppm
TA= 90ppm
CH= 235ppm
CYA= 52ppm
PH= 8
I find it odd that according to my pool specialist that I'm not making chlorine, they keep telling me to add this or that which I do but I can't seem to get my FC between the recommended 1-3ppm even though I'm sure I'm making chlorine ( cloudy water after water passing through cell fins )
So that's it I'll be happy to give you more detail if I can.
Thanks for looking
Cheers
2 Weeks ago
Salt= 3700ppm
FC= 0.07ppm
TC= 0.07ppm
TA= 32ppm
CH= 86ppm
CYA= 10ppm
PH= 7.2
1 Week Ago
Salt= 3700ppm
FC= 0.08
TC=0.08
TA=105ppm
CH=78ppm
CYA= 8ppm
PH= 8.2
2 Days Ago
Salt= 3700ppm
FC= 0.15ppm
TC= 0.15ppm
TA= 90ppm
CH= 235ppm
CYA= 52ppm
PH= 8
Thanks for looking
Cheers
