- Jul 6, 2017
- 20
- Vinyl
- Hayward Aqua Rite Pro (T-15)
Hello,
So having moved into a house 2years ago with a dilapidated pool and having just completed the house renovation, now my attention is turning to the pool to hopefully get it running for next spring. It's an IG pool (30x10', 14,000g) concrete with in-situ fibreglass lining, perhaps done at a later date to rectify a leak, not sure.
So, initially, I contacted a local pool builder for a quote for a full renovation. Given the size of the quote I'm looking to undertake some of the work myself and subcontract some specific jobs to keep costs down and am right now just trying to figure out my hardware setup.
Current thinking:
Vinyl liner: Aquaflex Alkorplan Touch Elegance (probably need to install some sort of padding to prevent fibreglass texture showing through). I'm looking for a pool that looks quite dark & moody rather than bright blue/green tinges, so I think I need a grey liner?)
Skimmers: AquaGenie (mainly as this would allow me to get rid of the main drain, as renewing that pipework under the pool would be a headache)
Auto topup: see Q1 below
Pump: Variable speed: Aquaspeed Eco-V 0.75HP. The existing STArite 1HP does work but it's oversized, especially if I go SWG, Q4 below)
Heater: Poolex Jetline 160 air source heat pump
Control Panel: Certikin CCP03
SWG: IC40 if I can find a UK supplier.
Filter: Certikin, Taeglus, Triton... what's the difference (Q3 below)?!
Cover: Poolock Manual Safety cover
Robot: DolphinS200
Lights: probably something from certikin
Current question:
1. Any comments on the hardware selection? Do I need an auto-top up to protect the pump, particularly if If I go with the Aquagenie and remove the main drain. On the flipside, in the UK and with a full safety cover I'm not sure evaporation will be much of an issue, only splashout
2. What pipe diameter should I be looking to utilise for flow/returns etc? 1.5" PVC and what depth is this normally buried to?
3. Any suggestions on filters?
4. The local PB recommended against using a SWG because of the hard water in the area and them having had issues with recent installs and scaling on the plates. Getting a TF test kit is difficult in UK (I'll probably end up buying the Lovibond MD200 6 in 1 in due course) but for now I have the local waterboard figures and my own test from installing the water softner in the house (total hardness 390ppm) or water board figures 323 mg/l
Given the range suggested for a SWG up to 300ppm, I wondered if I could just dilute the water fill with some of the house softened water to get back within the range. I appreciate that might take a little time running through the water softner and regen cycles but I think that should work?
The other item from the waterboard figures I noticed is the Alkalinity at 331. Is this the same as total alkalinity? In which case I would need to aerate to lower?
Thanks in advance!
Current thinking:
Robot: DolphinS200
Current question:
Thanks in advance!
