Hello. I am new to De pools.
We have a pentair FNS with multi valve.
The in-laws let the pool go for about 8month with no maintenance. I was deep green with frogs occasionally in it.
I started the process of shocking it, using yellow gone, chlorine, backwashing etc
When we put new DE in I could see it was coming out in the pool through one of the dish fountains. It would get really cloudy within 2 mins. This caused me to investigate more and I discovered it had bad spider valve gasket, also the manifold had cracks in it.
I cleaned and inspected all grids, no tears that I could see. Ordered new manifold. Installed (this was difficult and time consuming because they were not going on easy )
Turned the filter on and then coated the grids (DE in skimmer) I could see only a little DE was coming back into pool through the dish fountain.
I am not sure what to do. There is DE at the bottom of the pool from when the broken Manifold was being used. I can’t get this clear.
I feel we need to vacuum the bottom with Something that can really pickup this fine DE.
I have pics and videos of the DE going into the dish fountain about 2 mins after putting DE into the skimmer
This is after we stated shocking the pool. It was much greener than this before.
Few days later. We were told to add more chlorine and algecide
Later that day after adding the recommended.
Next day
This is the dish fountain that is cloudy
Cracked manifold. View attachment 406658
After installing new manifold yesterday
After running filter all night this is what the grids looked like.
We backwashed and added more DE.
Here is problem. When I brush bottom of pool white stuff comes out. I believe this is DE from when manifold was broken
Also after 2 mins of adding DE I can see this turn a smidge cloudy as seen in photo.
I need this pool clear before the 11th. Is this possible at this point? I can’t get anyone trustworthy to come out and help either. I need help!!
Next day
