Hello, I was wondering if a bad multi port could cause the water to reverse flow through filter and essentially backwash dirty water directly back through the returns. This is while I’m in filter mode. This happened after moving the multi port valve using the valve on waste to drain water out to filter. I moved it while pump was off and only in a clockwise direction as per usual. When I turned pump back on in filter mode, there was this massive white cloud coming out of the reruns for about 30 seconds. Now it’s just a bunch of air and water coming out of the returns. This is a sand filter too btw. Thank you.
