Hi All,
I am going to be installing a 24' used above ground pool this spring, I already have a spot where power is run out in the yard but it is quite a distance from the house. I am so far looking at getting the Pentair IC40. I do not have a problem with the hows of the electrical but is there a common practice for how to mount the power center in a remote location? My thought was to build a small lean-to from 4x4s and a slanted roof of some sort and mount the power center to the back wall, maybe corrugated metal roofing or to make it look nicer some plywood with asphalt shingles. Is this overthinking it, or would just 2 4x4s with it mounted on plywood in between suffice?
The pool and electrical connections are a good 20-30' from the house.
