InyoRob
0
As stated above, the most energy-efficient option is a VS pump. Pureline has a very economical 1.65 total HP option, model PL2605. Unless you take some flow away from the return jets, this pump will have to run at a higher speed to maintain your current flow.
Your C1200 filter is a single cartridge system. If cleaning the filter every six weeks is cumbersome, you may want to consider a quad cartridge system. You could go months without having to open it up and clean.
