*setup:
2 suction pipes out of the ground (skimmer & vaccuum) to a Jandy leading into the pump.
2 return pipes (water feature & return jets) split off of another Jandy back into the ground.
As I began my PVC/Pump replacement project, I always assumed both my pressure (visible) and suction (hidden by repairs/couplers) were 1.5" PVC.
After digging, I noticed that I have 2" coming from out of the ground on the suction side and 1.5" back into the pool on the pressure end.
1. Is this common and will it cause issues for me down the road? Over pressurized filter?
2. Is it safe to assume everything on the suction side is 2" underground?
I know there's not much I can do, but the mix of pipe sizes came as a surprise.
Thanks!
Thanks!
