Mixing chemicals
Mopar4u
48
Wisconsin
Im using a 5 gal bucket to dissolve applicable chemicals before adding to pool when applicable. What does everyone use as a stir stick? Wood, metal, plastic, other??
Pretty much no one mixed them in a bucket. We add them straight to the pool.
What chemicals are you mixing in a bucket? Why do you think they need to be pre-mixed prior to adding to pool?
What type pool do you have?
Fill out your signature with your poo and equipmemt specs. Add your testkit info also.
A piece of 1/2" pvc pipe works well as a stir stick.
Don't let chemicals get stuck in the pipe.
Reminder: Never mix different chemicals in the same bucket at the same time.
Clean everything well before and after using.
Sorry
Just updated. K2006 test kit
example: i added some ph down and instructions said to mix with water in a bucket first and then add to pool.
Perfect
Thank you
Sorry
Many (most) use Muriatic Acid (MA) instead of pH down. pH down adds sulfates to the pool water, which can cause issues. See this old thread:
Please don't post to that thread as its old. Just continue to post in your thread on this subject.
