- May 23, 2015
- 24,450
- Plaster
- Pentair Intellichlor IC-60
The cost was $525.
I'm not sure how much water went to waste. I do know that he hooked up a garden hose from my house to the trailer to replenish water. He also had a hose from his trailer to my sewer clean out to dump the waste. The water in the pool dropped by 1 to 1.5 inches during the process, but never below the tile line. My autofill took care of the rest after he was done.
Thanks for the info.
You can assume pretty reliably that the waste water rejection ratio is pretty close to 15-20%. So worst case scenario is that you'll see an extra 1,600 gallons (2.1 CCF) of water usage on your water bill (assuming you're on municipal water). Assuming the RO rates are regional (I'm down in Tucson), $525 would be more than the cost of me pumping my pool water out and simply refilling with municipal water (20,000 gallons roughly costs $156 if you subtract out the sewerage rate or $260 if you include sewer). However, I don't like the thought of flushing 16,000 gallons down my waste water pipe, so I might consider RO in the future.
Good luck with your new water!!
