Good morning
We are going to attempt draining our pool 1/2 way (high CYA)
Our pool company drained it last time. They used a submersible pump and 2" blue hose. Unfortunately, we were not there when they hooked everything up.
We have located a pump and a hose, available electric and we have a place to discharge the water.
but not much else.
Our questions:
1. Do we need anything else? It seems like there should be another fitting to connect the pump to the hose. I have read through Amazon and home depot and am lost in discussions of npt, mpt, males and females. If you use this system could you tell us what fittings you use?
2. After we get the pump and the hose connected what are the actual mechanics to start draining the pool? Do we just dump the pump in and turn it on or do we have to do something with the pool? I remember the pool company saying something about setting something to the main drain.
I know we sound like morons! We just bought our home on October 1st. We have never had a pool. We could ask the pool company to drain again however they are pushing us to do a total drain (we did a partial 22,000-gallon drain last week and CYA is still too high) and an acid wash to cure the CYA.
We really appreciate any guidance you can share.
Thank you
Steph
https://www.amazon.com/HydroMaxx-Di...coding=UTF8&psc=1&refRID=8X1Z9JV61K5E26QWR47R
https://www.homedepot.com/p/Superio...PIPHorizontal2_rr-_-204589831-_-204609991-_-N
We know the pump gets attached to the hose https://www.homedepot.com/p/Superio...PIPHorizontal2_rr-_-204589831-_-204609991-_-N
Our questions:
Thank you
Steph
