Water Chemistry Data
So I thought I'd end this thread with some useful numbers from my testing. Here are the test results before blasting (just looking at calcium hardness and total hardness, other parameters are either stable or have their expected variance from adding lots of fill water back in) -
5/17 (TH = total hardness and MH = magnesium hardness)
TH = 1560ppm
CH = 1320ppm
MH = 240ppm
5/19
TH = 1480ppm
CH = 1240ppm
MH = 240ppm
So, as you can see, the total hardness and calcium hardness of the pool water went down by 6.1% (using the CH numbers to calculate this) due to all of the draining, backwashing and refilling with municipal water (CH=180ppm & TH = 210ppm) BUT the magnesium hardness remained constant. So one has to assume that the blasting media, which is basically magnesium sulfate, added enough magnesium hardness to compensate for the drop in total hardness. One would also assume that the municipal water added to the magnesium hardness as well, but it’s pretty minimal. If you assume that the blasting media added it all, then that’s a conservative enough assumption. Since the hardness is measured in molar mass units of CaCO3, one can convert the 6.1% increase in magnesium hardness into magnesium sulfate and then determine the increase in sulfate concentration -
MH * 6.1% = 15ppm CaCO3 (this is the amount of hardness added by magnesium sulfate)
15ppm CaCO3 = 18.1ppm MgSO4
SO4 content added = 14.4 ppm in SO4 units
So then entire process increased my magnesium hardness by 6% and added ~ 14.4ppm of sulfates to the water. It's always best to keep sulfates low when one operates an SWG but 14.4ppm isn't very much and concrete studies have shown that one needs to be up around 300ppm before "sulfate attack" becomes a problem. Given that I will be draining a large portion of the pool water over the coming weeks, my sulfate levels will only go down.
All in all, while expensive to have cleaned this regularly (I only got 3 years between cleanings), the process does a good job with minimal impact on water hardness and sulfate levels. I hope this helps anyone who might be considering this process.
Here’s what Mr T cleaned off the bottom of the pool -
