Hi Guys,
I know this topics been discussed many times and I've ready those posts but my situation seems a little different so I wanted to start a new thread.
Bought my current home 4 years ago and the heater came with it. It's worked fine for 3 years. I've had to replace some wires that were chewed by presumably a chipmunk or one of my dogs each year the same wires get chewed and I fix them and everything works. This time that was not the case. Pump has error code E06 for fault in the stack flu sensor. Control board is old style on top. Service heater light is on. Under side of the control board has SFS light illuminated. I shut off the breaker and flip it back on and same thing. I pulled fireman fuse and the same code appears. I ordered a stack flu sensor, turned breaker off, replaced sensor, turned breaker back on and no change. The heater will not turn on at all. None of the buttons on the control panel work. It just displays E06 and the service heater light stays on. I checked the stack flu for blockage and it's clear. I checked all wires and they look good, nothing chewed. Could it be that the SFS I bought is just a bad one? What else can I do to troubleshoot this issue?
