As I understand it, the minimum acceptable water flow for a Pentair Mastertemp 400 heater is 40 GPM. My understanding is that there is a flow switch (or pressure switch or something) in the heater that will not allow the heater to turn on if the flow is lower than 40 GPM.
My heater however will turn on and heat the water when the flow is only 21 GPM (21 GPM is the normal amount of flow that I get when in Pool mode with my pump set to 1,600 RPM).
Is something wrong with a sensor on my heater, since the heater will turn on even though the flow is only 21 GPM?
