3 year old pentair master temp 400
heat will not fire, blower does not even turn... heat is set at 89*. membrane is showing water temp 107... easy touch panel temp reading is accurate (thermometer in pool 83*). I even dropped the pool water sensor in ice water to confirm... while the easy touch and my ScreenLogic both read 36*, the membrane panel on heater stayed on 107*.
the membrane LEDs should not even be on because controlling heat through screen logic...
tried bypassing membrane by jumping first two pins on master temp control board, nothing. no lights on heater control panel when buttons on membrane are pushed...
my question is, does this sound like a bad board in the heater?
