Been fighting a cycling Mastertemp 300 heater for most of the summer season. It would start to cycle once the temperature would reach around 88 degrees, cycle again and then eventually the service heater light would come on. This would occur when heating the spa or pool.
So I:
1. Checked error codes and there were none.
2. Made sure I had good flow, backwashed a few times, cleaned filter...still cycled..uggh!
3. Removed the thermal regulator , seemed discolored, replaced and it still cycled: uggh..
4. Bought a new bypass valve as maybe it seemed like it stuck a little?, replaced...still cycled..ughh
5. Bought a new high limit switch, gotta be bad right?..replaced..still cycled...uggh!
6. New Control Board!..this is it right!, replaced it..still cycled..uggh.
At this point it was starting to get personal!! Ha and a little $$$. But I was determined to fix this thing without calling a service rep. In the back of my mind I always knew it could possibly be the cooper tube sheet being corroded and preventing proper flow of water or heat, but also knew it is a pain to check, but I trudged ahead, took the heater basically apart and below is what I was greeted with:
I went ahead and ordered a new tube sheet, cleaned and de-rusted the bowl it was in, got it installed and now the cycling is gone.
Don't know why I did not get any error codes and my chems are also in line, never had algae etc... Maybe the salt water? Maybe that's just the life?
I don't have a bypass so water is always flowing through it, think maybe I'll add one. The heater is about 5 years old, but none the less it is SOLVED!
So I:
