Manual pool vacuum suction
SeanB
Platinum Supporter
I know that most manual pool vauums attach to the inside of the skimmer and work off the main pool pump. If I understand correctly, these work best if you can isolate the suction to just the skimmer.
Our configuration does not allow seperation of the main drains and the skimmer. Would that still be an effective way to clean or would the suction be too low? The polaris cleaner does a great job of cleaning the pool, but I'd like a way to clean out the spa a little more effectively.
Can a manual vacuum be attached to the intake for the polaris, which runs off its own pump?
TIA.
G
Guest
#2
Every pool is different. It might work just fine. Only way you can find out is to try it.
A spa wand is among the easiest ways to clean a spa It is manually operated and it works extremely well! Some of them even come with variousl brush and nozzle attachments.
In a word, No. Don't even think about trying this!
TIA.
divnkd101
587
0
50
Pearland, TX (Houston Suburb)
#3
Sean,
I have no separation either. However, I can control each skimmer and shut them down if necessary. If you have that ability, shut one of your skimmers down. That should provide you enough suction to vacuum. I have done mine a couple of times with plenty of suction necessary. Good Luck.
G
Guest
#5
Exactly what you need. I have one made by Game. It was cheaper than the Polaris, came with several snap on attachments (brush, skimmer and 3 different sized nozzles) and a mounting bracket so it's always handy!
