Manual Pool Vacuum on Suction Cleaner Outlet
Jun 15, 2017
58
Winter Park, FL
Greetings Everyone!
I plan on vacuuming my pool here shortly and I do not have the plate that fits over the skimmer basket for the hose to attach... I do, however, have a suction outlet that would normally be used for a suction side cleaner. Can the hose be hooked up to that outlet for manual vacuuming? I could see the trouble if I were to be cleaning up large amounts or large size of debris that could damage plumbing/filter, but I would only be sucking up smaller bits of sand and knocked loose pebbles. Anything larger is already scooped out. Is there a danger I am missing?
Thank you in advance to those who read and/or reply!
I wouldn't worry about it either - if your hose fits, you shouldn't have problems with small debris. There are adapters if your hose doesn't quite fit, and if you want to be extra careful you could buy an in-line basket for your cleaner (though at that point it may save you time/hassle/money to just buy the skimmer plate).
