Right now my plumbing can be configured to dead head the pump (bad). Or trap water in heater (bad). A flow switch can make this setup safer for the heater (thanks @JamesW!) , but I think I can also fix another way myself.
- Add new Jandy Check Valve (yellow box).
- Position "Lock Open" valve where no flow is blocked, and remove handle.
- This should have been a check valve in the first place.
- Reposition last 3-way (right above pool return) so the intake coming in the top cannot be blocked.
- This would allow for only spa spillover, mix spill/return, or only pool return.
