- May 31, 2012
- 973
- Vinyl
- Jandy Aquapure 1400
On Oct 6 a new spa opened just outside of Toronto Thermea Spa in Whitby, ON. Within a few days many customers complained of a rash. It turns out that pseudomonas and staphylococcus (or staph) bacteria was found in the water at one of their outdoor pools. The spa is now facing a $5M lawsuit.
See stories: Guests suing Whitby, Ont. spa, seeking $5M in damages after contamination - Toronto | Globalnews.ca and https://www.cbc.ca/news/canada/toronto/whitby-ontario-spa-audit-update-1.6639145
Here is what the spa has posted on their website. Does this make sense or is this BS?
At the conclusion of our audit, we found three factors that contributed to the bacteria
being found in the Källa pool.
One:
− The Källa pool’s primary disinfection system was a bromine erosion system,
which feeds the sanitization chemical into the pool. In Ontario, all pools
must be treated with either bromine or chlorine. Bromine was selected
because it was understood to be an effective chemical treatment in warmer
temperatures and less irritating to bathers than chlorine.
− Our standard operating procedure requires a manual test of each pool every
two hours. When we launched, all tests indicated that bromine was being
released at the appropriate levels.
− According to our audit, however, a valve on the bromine erosion system failed
sometime after launch. This impacted the amount of bromine being released
into the pool. We have not been able to determine yet if this was due to a
manufacturing defect, installation error or some other cause.
− As part of the initial solution, we replaced the valve on the bromine erosion
system and installed a redundant bromine system as an additional backup.
Two:
− The Källa pool also came with an ultraviolet disinfectant system, which
functions as a secondary safety measure, to destroy any bacteria that escapes
the bromine. Our audit found a ‘flow switch’ malfunction, which caused the
ultraviolet system to fall into maintenance mode and not serve its primary
function.
− As part of the solution, we proceeded to replace the flow switch on the
ultraviolet valve system.
Three:
− Further testing indicated that the highly concentrated solution of salt (14%)
in the Källa pool impacted the bromine puck’s ability to dissolve in the water,
therefore the bromine was not acting as a complete chemical barrier to the
bacteria, as we had been advised it would.
− All other pools at Thermëa spa village in Whitby (and across Canada) operate
with chlorine. Injection valves and chemicals for the other pools in Whitby
have been carefully examined and there are no irregularities
