Hey so I switched to using liquid chlorine this summer. Pool has been crystal clear and I add 10% Pool Essentials chlorine daily to a target FC 7-8. I typically have to add 2 to 3 quarts, maybe a full gallon once in a while when it’s been hot in NJ and I may go down to FC 4 which previous post answers have said is typical. My timer broke on the filter so I have to manually turn on/off usually about 4 hrs every morning.
We are planning to go away for 3 days and I want to maintain pool well. So do I raise the FC way up the day before I leave and to what level? I do have some pucks from the beginning of this summer before I started using liquid chlorine but since the timer is broken I can’t put them in the chlorinator so I can buy a chlorinator for in the pool. How many pucks should I put in if this the option to not screw up the CYA so I can resume using liquid chlorine when I return? Or do a combination of both?
Thanks in advance.
Thanks in advance.
