- Jun 20, 2017
- 29
- Plaster
- Jandy Truclear / Ei
OK, taking it off and checking for damage of the diffuser.After you've completely cleaned from the impeller area, put her all back together, turn on breaker and try starting her
Before I put it back together, how do I locate this switch? There is a black thing that has 230 on it and it looks like it might be a jumper, but not familiar enough with these things to be certain. I don't see a way to "switch" it per se.If all else is ok then take a look at the switch on the back of the motor shaft as it may not be turning on the start winding. Because it is hot makes me think this.
