I am installing an ET8 with a 220v/60amp circuit in my main panel, but I'm unsure of the conduit and conductor/wire size that is required. The ET8 will be about 60' from my main panel.
I will be installing:
A few questions...
I appreciate any advice!
- 1 - Pentair VS Pump
- 1 - 400k BTU heater
- IC 40 SWG
- 3 - 120v Pentair 5g color LED pool lights (all on same circuit)
- 1 - 120v Pentair 5g color LED spa light (separate from pool lights)
A few questions...
- I was thinking 4 awg in 1" PVC conduit.
- Will I run 2 Hot, 1 Neutral, 1 ground or will the neutral serve as the second hot?
- Does the breaker in main need to be GFI or only the breakers in the ET8 out to Pump and Lights?
- Is 220v/60amp adequate for equipment? I believe so and I only have a 125amp main, so I'm limited, but I won't be upgrading the panel for this project.
