- May 3, 2007
- 16,895
- Plaster
- Hayward Aqua Rite (T-15)
On full speed, how much does the filter pressure change from post backwash to basket filling with air?
If the pump basket fills after backwash but gains air over time and full speed no longer clears it, there could be two things going on. An air leak and algae bloom.
But to answer the question, larger pumps produce more flow rate so it is easier to prime. However, a larger pump can also produce more suction head so more inclined to leak air. But it is a VS pump so none of that matters since you have full control over the "size" of the pump via RPM.
