- May 29, 2023
- 35
- Vinyl
- CircuPool Edge-25
Upstate NY, 12.5K gal above ground vinyl pool. Added Circupool 25K this year. Started balancing water and added salt. I screwed up something bad, and I'm not even sure how I messed up so bad.
I bought new test strips (yeah, I know) and they showed pH was low, so I bought some pH UP, and added according to the probably terrible instructions on the bag. Tested the next day, and used my drop test kit with new bottles (just the cheap ones). pH was purple, off the chart high. I thought something must be wrong, since the test strips showed pH about 7.6. Test strips also showed ALK was low, and based on that number I added 4lbs of baking soda.
Clearly I am messing stuff up worse, pool became cloudy.
Meanwhile, I am running the SWG and my test strips show salt at 3500.
I decided to STOP and take water to the pool store where they have a computerized tester. They ran it and told me I was all kinda screwd up.
FC 0.4
TC 3.52
CC 3.11
pH 7.6
ALK 150
Calc Hard 84
CYA 14
Iron 0.1
Copper 0.1
SALT 4000
Told me to add 1 gal of Muriatic Acid with the pump off, in blobs around the edge, and wait overnight. Then turn pump back on and wait for a day and bring back in to test.
Then I remembered this website, and came over here and started reading. This morning I tested (drop test) and ph was 6.8. Tuned on the pump and turned off the SWG, and aimed the return to the sky. Making a nice bubble fountain. I will leave it this way until pH comes back up as far as it will. How long shoud this take? Can I shock while this is happening or do I wait?
Looking for help. I am ordering the T100 test kit today. I want to make sure my pool doesn't turn into an algae pit (very very sunny this week, but at least the pool is still cold, 68F). I can use the pool store testing until the test kit comes, and/or the walmart drop test. The test strips are apparently pretty useless?
FC 0.4
TC 3.52
CC 3.11
pH 7.6
ALK 150
Calc Hard 84
CYA 14
Iron 0.1
Copper 0.1
SALT 4000
