jmastron
Edited post:
That’s a good idea. I do want a larger measuring cup for the MA. You do have to be careful of what plastic you use with MA and I’m finding it a bit difficult to find measuring cups made from plastics that are safe to use with MA that have all the different measurements printed on it that I like. I’m going to get a larger glass measuring cup.
Like others, I use plastic measuring cups and never really considered the material/compatibility especially since the liquid is only in it for a minute. I don't think any of the standard clear plastics used pose an actual danger (like melting immediately and spilling); if one did start to cloud/degrade it would be obvious over time.
Having said that, I don't measure muriatic acid like that anymore. I took a stick of wood and an empty jug, filled it with water measuring quart by quart, and marked the levels on the stick. Now when I get new MA jugs I mark them with a sharpie, and pour directly from the jug into the pool. A quart at a time is about right to drop my pH from 7.8-8 to 7.4-7.5, and since I'm doing that based on testing it doesn't have to be exact. Much less exposure to fumes this way.
I do wear chemistry goggles when the MA jug is open, since the splash risk is high. I don't bother with gloves, since I understand the risk to skin is minimal if you wash it off quickly, and I have 25,000 gallons of water readily available to do that I don't wear a mask -- like others said, better to smell the fumes and close it/move away than to not smell them and have eye damage.
