So - opened the pool 4 days ago, other than 5 pounds of dead worms, everything looked normal (pool installed 2015). Vacuumed those suckers to waste, cleaned everything, hooked up plumbing and charged my DE filter with slurry poured into the deep-end skimmer (grids were stored clean). Next morning, checked my FusionSoft control center and had a "NO FLOW" message. Undid everything looking for possible blockages (returns were flowing weakly compared to "normal"), didn't find anything.
Popped open the filter "egg" to check the grids and noticed most of the DE was lying the bottom 1/3rd of the egg. Took it all apart and cleaned the grids, reassembled and charged with DE powder added slowly to the same skimmer. Turned system on and had FLOW (yay).
Checked system 24 hrs later - NO FLOW again. Cleared skimmers, checked return outflow and felt it was weak again. Popped the "egg" open and now the DE was covering the top 1/3rd of the grids - very uneven distribution. So, my questions:
With two skimmers (shallow and deep end) and deep end suction drains, what is the best method for charging the DE grids?
- close main drain and one skimmer, add DE to other skimmer? Leave all valves open?
- run pump at lowest, medium or high speed?
- slurry or dry-add method?
My filter is a Jandy DEV48. It recommends the slurry method. How long do the grids last?
Thanks
Thanks
