Hi All,
I have my ProLogic Hayward two speed pump set to freeze protect start at 34°F. In the two speed Hayward system this initiates with high speed for three minutes, then shifts to low speed operation. This has been working fine, but today, following a couple of nights of temps below the 34° set point, the high speed was cycling on and off, but never activating the low speed side.
So, once temps were above 40°F I tried starting in low speed (toggle through high to low), but the high speed did not start nor did the system display show the expected start and countdown for three minutes. I first cycled the ProLogic device power off and on, then selected the low speed cycle (high speed for three minutes then automatic shift to low speed) - high speed started and the display showed the low speed countdown, but at the end of the countdown, the low speed pump did not start. I then selected low speed, again, without cycling the controller power - the high speed did not start, nor did the low speed countdown begin. I did this twice more to ensure it was consistently behaving this way - nothing changed.
So, I cycled controller power, again, then selected low speed and the countdown began, but at the end of countdown, with my finger on the bottom of Aux Relay #1 on the actuation pin, I neither heard Aux#1 click, nor felt the pin move. I think this means the relay did not operate.
I plan to substitute the Lights relay to see if this brings low speed back on-line ... if it does, I'll leave it configured that way and replace the Lights relay. Does this sound like the appropriate course of action?
Thanks!
Thanks!
