- Jul 21, 2020
- 36
- Vinyl
- Hayward Aqua Rite (T-15)
Correct. The generator should not be powered when the pump is off.I’m reading that the flow switch is a safety mechanism and not meant to be the primary means of shutting off the generator?
See James' post on the Intermatic T104. You can use a separate timer for the SWG or share one with the pump. If you are not comfortable with pool electrical, have an electrician that works with pools do it. Pools and electricity are not to be played with willy nillycan I theoretically just shut the swg off when my pump is scheduled to not be running..?
