- May 23, 2015
- 25,695
- Plaster
- Pentair Intellichlor IC-60
Was there a question in the original post? I didn't see it.
Are we arguing some deep end stuff that really has no bearing on TFP methods? Seems like it to me.
Maybe. But I think it’s important to at least discuss the proper role of different types of testing. The OP’s original post was to elevate ORP and visual comparator testing above titration testing because those results seemed to correlate better. But as James pointed out, without a verifiable way to check the tests using a known standard, you can’t make that assumption.
Here’s the deal - humans don’t like results that don’t fit with their preconceived notions of what is correct and what is not correct. It’s called “confirmation bias” - we like results that fit our personal preferences and we push back against result that don’t conform to our understanding. We see this all the time in medicine - people get a bad medical result and they’d rather blame the test or blame the medical provider rather than blame themselves, their behaviors and habits, and/or their circumstances. Pools are similar - when we get test results we don’t like or that don’t fit our notion of what’s going on, we hunt for complicated solutions to answer the problem at hand.
Here’s the point - it’s well known that the DPD-FAS titration test is highly accurate. It’s been established a billion times over. So if there are other tests that are showing results different than the DPD-FAS test and there’s nothing wrong with the DPD-FAS chemicals as far as can be known, then it makes much more sense to be suspect of those other results rather than blame the DPD-FAS test.
