DESPERATE
I work with dogs who have mobility issues in an indoor pool. High bather load. 4000 gal. fiberglass pool, 30" filter using filter glass plus UV light.
I have been having a lot of trouble with cyanuric acid build-up, so I decided to switch from tablets to liquid chlorine.
Drained pool and refilled. Added liquid chlorine. All good. After working, the next day water was cloudy and no chlorine according to test. Added 20 oz of liquid chlorine and this morning nothing registering on test. I added a dichlor tablet and chlorine came up a bit after a few hours. I couldn't add liquid chlorine because we were using pool.
Would granular unstabilized chlorine remain in the water longer?
Leslies has Power Powder Plus?
Also, checked PH after filling the pool with fresh water and it was very high. Perplexing--ok to drink but bad to swim in?
and Calcium Hardness was very low.
Finally, why are my numbers different than Leslie's Pools when they check my chemicals? I am using Taylor test kit.
Thank you!
Thank you!
