Ok, You do have a suction side cleaner and I have a guess.
It's gonna require you to run a couple more tests.
First, my guess. You have a suction side leak in the skimmer line and it doesn't leak water out when your pulling from it. However, when you switch to the vacuum side, the suction head (negative pressure) in the simmer line goes positive and it leaks water out.
I want you to plug the hole in the bottom of the skimmer that's coming back to the pump and open the valve to the vacuum line. Then run the bucket test overnight and see if it shows a leak. If it doesn't then that pretty much confirms my suspicion.
Post back once you've done the test and we'll go from there.
