I desperately need help with mustard algae.
My pool chemistry as of 10 AM today using Taylor K2006 and TF100 kits:
FC = 6
CC = 0.5
pH = 7.2
TA = 70
CH = 170
CYA = guess of 10 (keeping trichlor pucks in floaters and based on FC
readings). The test has slight cloudiness when done, but doesn’t hit
the 20 mark on the TF100 CYA test tube
I apologize for how long this is going to be. This is what has been the status to date:
Up until this year, the pool has been easily maintained using TFP methods with a max of 3 green algae blooms (1 due to my surgery and the other 2 when opening in the spring).
We opened the pool on May 7th this year and within one week, brown sandy streaks and blotches started formed on the shallow end floor, in skimmer bases in front of weirs, and all around the crease where the floor meets the wall in the deep end.
It's a 39,000-gal pool vinyl liner pool. We have a VS pump that I have been leaving on 24/7 running at 50 gal/min (2400 RPM). The filter is a 72 sq. ft DE grid filter (installed this May). All returns are pointed downward and the main drain is 50% open.
I have been keeping 3 floaters in the pool with 4 of the 3 in. trichlor pucks in each of them because I am keeping the SWG off while adding chemicals and my CYA has been trending down.
I had added 12.5% liquid chlorine shock from May 16th through July 2nd to maintain a free chlorine (FC) level of 15 while keeping the pH around 7.3-7.6. I tested the chemistry every 2 hrs. initially, and then 3 times a day as I became familiar with the situation.
The TA has drifted down from 90 to 70 and the CYA dropped from 30 to 10 (best guess). The CC has ranged from 0 to 0.5, but no higher. And...my phosphates have increased from the baseline of 200 to 750. So far, the test for nitrate has been negative. There are no metals in the pool and no algaecides have been used.
I followed the SLAM OCLT procedure before starting the Mustard algae battle and have done 5 successful OCLTs throughout the process.
I have been keeping debris out of the pool and brushing the whole pool (skimmers included) every day...sometimes twice a day (I missed brushing June 11th - June 15th , but did remove debris) and I have been sanitizing any hoses, poles, brushes, etc. I also removed and sanitized the ladder from the deep end (have not put back in pool yet), vacuumed to waste 3 times, and I have back-washed the filter 3 times.
There are 4 fiberoptic lights that fit snugly with the vinyl liner.
It seemed to disappear in 1 - 2 weeks initially, but as soon as the FC fell below 7 PPM (with daily brushing), white sandy patches showed up in the same places in the shallow end only.
So, I kept repeating the process where I continued for a week and then let the FC drift to near 7. Without fail, I would see the same patches again.
A week ago (around July 2nd), I decided to switch to Cal-hypo 73% since my CH was 130. The patches now show up at a FC level of 12 and they are darker, in the original spots and spreading! I am SO frustrated!
I would prefer to not use algaecides, but I’m, getting desperate…. half of the summer is gone, and nobody has been in the pool
Help? Thank you.
FC = 6
CC = 0.5
pH = 7.2
TA = 70
CH = 170
Help? Thank you.
