We
We are doing #1 with our Bobé Water features. It’s currently covered due to rain. But once it clears, I will take some pictures. But our four water features have their own line from the equipment. Three of mine are grouped together and one in the corner, so I have the ability now to keep all four on at the same time or turn off the large one and keep the three smaller ones going (or vice versa). All four water features are being run off their own 2hp vsf. Our three “u” scuppers are 18” long and the corner is a 3’ Radius.
Thanks Mark,
Can you tell me how you did the math?
Also, for the plumbing on the features, I was under the impression that I had two options to balance the output.
1. The plumbers that have seen the job so far recommended running a 1.5" line to each water feature from the equipment pad, with ball valves at the pad to control the flow to each.
2. I saw a picture online that seems to suggest that you can hydraulically balance the output by looping plumbing around from one inlet straight in its center. Can this method be used for 5 outputs over a 30 foot distance or does the concept fail?
