- Jun 22, 2014
- 52,024
- Fiberglass
- CircuPool RJ-45 Plus
So, assuming you completed the 10-minute FC tests to consume anything eating your chlorine so fast (or do it first-thing in am), you are correct in that you will start your SLAM FC level at 10 since your CYA is currently next to nothing. At the same time, you should have ready a sock with granular stabilizer to start increasing the CYA to at least 30. It will dissolve in about a day, but may take a week to show-up on tests. So yes, even after the 10-minute checks, once you start the SLAM, FC will get eliminated quicker than if there was no CYA at all to protect it, but you have to move forward anyways. You won't have to add bleach as quickly as when you did the 10-minute checks, but you should be prepared to check it every 1-2 hours or so - especially in the early part of the SLAM.
