I think that there is a lot of waste because they have to cut the pattern from the rectangle.It does seem odd that the cost would be based on measuring the largest possible rectangle you would need to cover the pool when the actual cover would not be anywhere near that size.
The webbing/strap spacing is also a factor.My 989 Sq ft cover is $3300 installed.
Highly recommend contacting COVERTECH directly. Then calling around to ask for installation services. I found a local place that was a COVERTECH dealer, but ordered direct. I was able to work with a direct sales person, and arrange shipment directly to my home. Even with freight and $450 install from local pool store, it was less than half the price of local quotation.Hi,
Which cover did you end up getting?
I also just got quoted like 10K for a Looploc
