Looking for suggestions on backwash hose connections
rajung
470
Cedar Falls, Iowa
I need to replace my hose this year again, 1 1/2", standard, thin wall cheap hose.
I think about going to a reinforced style since these don't last for me as I have to go across land scape rock and such.
My multi port has the regular slip on type fitting for hose but those are a hassle getting the hose to slip over, really tight .Anyone know if there is a twist lock style connection possible like the discharge hose set up like for sewage , landscape pumps? Sure would be quicker for opening / closing time. Plus if I go to a re-enforced style hose I bet it would be even more stiff to connect. Could be I am over thinking all this , lots of time to think with this long winter weather.
1 3/4" fire hose - you can find them on ebay and other places for a reasonable price. Or call your local fire department and ask what they do with their de-certified fire hoses. Sometimes they will give them away for free.
1 3/4" fire hose will fit (snug) over 1 1/2" PVC. If you look around, you can also find adapters and/or quick connects to make hook up easier. Since you aren't using the hose with lots of pressure, the fire hose itself should last you pretty much forever - as long as you drain and bring inside in winter.
Reactions: MyAZPool
I ended up going with a cam lock style fitting, although made out of nylon / plastic- not aluminum , and re enforced blue hose 1 1/2"
I need 75 ft so will trim 25 ft off of this 100ft hose I bought.
Even this hose at 100 ft weighs 13 Lbs. Now just to work on a reel set up
Thanks to all for ideas.
