To be honest, after shocking the pool and waiting a day, the pool is crystal clear like it was a few days ago. FC was 3.5 prior to adding the shock but I think due to my high CYA, I was getting a little chlorine lock and had to up the amount of FC to get the same effect. Pool still looks 100% perfect right now after a day with zero CC from the TFTtest kit. PH was a little high (8.0) but I got that under control pretty easy with acid. As I understood it, there no added CYA in the shock I used as that would have just caused more of an issue. As for the white spots, they showed up after I opened the pool this year and I just got around to posting the question. I was able to remove them today with a pumice stone.
