- Aug 25, 2011
- 589
- Vinyl
- Pentair Intellichlor IC-40
They came out and pulled the liner and we have a relatively significant amount of water coming in by the stairs there (basically under the plastic on the bottom and seems to work it's way to the right). There's a french drain around the pool because they thought this was a problem when building it, but it actually wasn't - they cut my sump pump line so it was filling the hole but once they repaired that it was fine. So this has developed in the 11 years since the pool was built and I've not really had any issues. I dropped my pump in the french drain but it's too high and the bottom of it is about 8 inches off the floor of the pool. I pumped it for 3 hours and then there wasn't much in there, but it did look like a trickle was still coming into it. Maybe that will help overall but who knows.
The liner guy says this is pretty typical looking for a saltwater pool but the water is a problem. He said they normally put something along the base (they weren't the ones who built it), but if it's that wet, they won't be able to. So, to that end, what can we do about that water coming in??
