We'd like to put some lights around our pool as our back yard is pitch dark at night and we only have one porch light on the house. There is a light in the pool, but we'd like light outside of the water, too. I've done some searching and have seen different things - 5ft from the water, 10ft from the water, different rules for aerial lights, etc. I'm still not confident on what's ok and I don't want to do anything unsafe, hence yet another post about lighting.
We have an above ground pool. I was thinking about mounting lights to the fence around the yard as that would get the lights higher than the pool edge (about 3ft difference in height). However, the side of the pool nearest the fence is only 8ft from water edge to fence. If the lights are permanently mounted to the fence, would this be ok? Is there a difference if it's 110v Christmas type lights, or low-voltage LEDs? The power source would be the pool equipment pad, mounted on a board with all the other outlets/equipment.
If the fence isn't ok, then the next plan is to permanently mount lights on the house, on the gutter. This is far more involved so it's not my first choice. The house is a couple inches over 10ft from the edge of the water, but those lights would be 10-12 ft high.
