I'm back guys! Quick question. I have the dirt pretty level. I'm ready for the next part. For the legs, you DIG down until the TOP part of the blocks you are using is level with the ground correct (ALSO NOT on the sand at all if you use some)? Then a little bit of sand will be around those legs. Just wanting to make sure because ALOT of videos people have put their legs on a block that's ONTOP of the ground. I'm guessing they are just doing it wrong BUT it's almost every video I've seen. I'm also going to use a weed barrier under the tarp that's under the pool but also let the weed barrier go about 6" past then put some rock on it. Only way I see that working is if the weed barrier is between the legs and the block that's level with the ground, is that a good idea....? Wouldn't that mess up the weed barrier?
