So I just finished wiring up my Globrite LEDs (3 of them). When I first turned them on, only two of them worked which turned out to be a faulty LED. After the service guy came and replaced the faulty one, he called me and said that you can turn them all on once, and when you flick the switch off and then on again (to cycle through the colors), the GFI trips.
Note, that I wired the switch from a GFI outlet next to it for safety.
So what's the deal with it? I know some GFI outlets can be touchy so I can try replacing the outlet this weekend however it's I tested it this morning and he is right.
Turn them on - OK
Turn them off
Turn them back on - GFI trips
Reset GFI
Turn them on - OK
Turn them off and then on again - GFI trips
What gives!?
Turn them on - OK
Turn them off
Reset GFI
Turn them on - OK
What gives!?
