Leaking pump seals
Rrebel
Active member
May 30, 2018
44
Aruba
I'm trying to help a friend repair leaking O-rings on his EQ1000 pump.
I bought an O-ring set that I'm trying to install. Now I can't get the pump back together; the O-ring on the diffuser won't slide into the housing. I've already applied a generous amount of O-ring lube, but it's still not working. I've used two threaded rods to press the pump together, but it still won't go in. I'm afraid to use more force.
Am I overlooking something?
