My new Intex 16x32 pool is leaking at the SWG output to the pool.
Krystal Clear 2150 GPH Pump, 16" Sand Filter System and Saltwater generator.
When first assembled it leaked so I took it apart and put it all back together and it ran fine for a while but sometime in the night it opened up again and I lost ~640 gallons overnight.
I can't really tighten the nut as it jumps after once it gets to the point of tight. It is not crossthreaded and there doesn't appear to be any gross defect in the threads of the nut or the SWG output.
The hose holds fine when attached directly to the sand filter. So for now I am doing manual chemistry and running the sand filter.
Any suggestions?
Any suggestions?
