I think I have a leak in my skimmer faceplate. I have gone through the testing for evaporation, turning off the pump to see if the leak is in the liner or the plumbing, and checked any areas that would be culprits for a tear in the liner. Now I just need to know if I should remove the faceplate to investigate or if I should simply use some of the underwater putty stuff to create a seal around the faceplate of the skimmer. I am going to use a dye leak detection kit tomorrow just to make sure that's where the leak is before I actually move forward with the repair. I'm pretty sure this is where the leak is though. Thanks.
